Learn about the camera’s accessibility functions (user assistance functions)
See below for information on various operation procedures. Also refer to the camera’s Help Guide.
Screen Reader
Only some languages may be supported for this function depending on the model. This function is available only when the language set in the menu is supported by this function.
How to enable the screen reader function
Once you use the screen reader function on the initial setup screen, the screen reader function will be kept enabled after the initial setup, and you can switch on and off for the screen reader function by pressing and holding the MENU button.
Note: The MENU button is located on the rear side of the camera, the left side of the eyepiece part of the viewfinder, immediately above the monitor, and is a horizontally long-shaped button.
If you have not used the screen reader function on the initial setup screen, you can enable the function from the MENU.
On the MENU screen, configure the following settings:
Select
How to set the speed when reading aloud
Select
How to set the volume when reading aloud
Select
How to enable the screen reader function by pressing and holding the MENU button
Select
Enlarge Screen
How to enable the enlarge screen function
Select(Setup) →
Accessibility → Enlarge Screen → Enlarge Menu Scrn → On (Custom Btn 2)
How to set the magnification to use for the function to enlarge the screen display.
Select
Focus Magnifier
How to enable the focus magnifier function
- Select
(Focus) → Focus Assistant → Focus Magnifier
- Press the center of the multi-selector to enlarge the image and select the area you want to enlarge using the top/bottom/left/right side of the multi-selector.
How to use the focus magnifier function by touch operation (When shooting in manual focus mode)
When Touch Func. in Shooting is set to Touch Focus, you can magnify the image and adjust the focus by touching the monitor.
You can perform Focus Magnifier by double-tapping the area to focus on while shooting with the monitor.
While shooting with the viewfinder, a frame is displayed in the center of the monitor by double-tapping and you can move the frame by dragging it. The image is magnified by pressing the center of the multi-selector.
- Select
(Setup) → Touch Operation → Touch Operation → On
- Select
(Setup) → Touch Operation → Touch Panel/Pad → Set properly for your use.
- Select
(Setup) → Touch Operation → Touch Panel Settings → Shooting Screen → Shooting Screen → On
- Select
(Setup) → Touch Operation → Touch Panel Settings → Shooting Screen → Touch Func. in Shooting → Touch Focus
- Select
(Setup) → Touch Operation → Touch Pad Settings → Set properly for your use.
Focus Map (Movie)
How to enable the focus map function
Select
Peaking Display
How to enable the peaking function
Select
How to set the level of enhancement of in-focus areas
Select
How to set the color used to enhance in-focus areas
Select
Subject Recognition in AF
How to enable the subject recognition in AF function
- Select
(Focus) → Subject Recognition →
Subject Recog in AF → On
- Select
Recognition Target → Select a subject.
Touch Tracking
How to use the touch tracking function
- Select
- Select
- Select
- Select
(Setup) → Touch Operation → Touch Panel Settings → Shooting Screen → Touch Func. in Shooting → Touch Tracking
- Select
Touch Focus
You can also touch a subject to focus on it when shooting movies. (When shooting with the monitor)
How to enable the touch focus function
- Select
- Select
- Select
- Select
- Select
Note: This function is available when Focus Area is set to Wide, Zone, Center Fix, Tracking: Wide, Tracking: Zone, or Tracking: Center Fix.
Touch Shutter
How to enable the touch shutter function
- Select
- Select
(Setup) → Touch Operation → Touch Panel/Pad → Both Valid or Touch Panel Only
- Select
- Select
(Setup) → Touch Operation → Touch Panel Settings → Shooting Screen → Touch Func. in Shooting → Touch Shutter
Touch AE
How to enable the touch AE function
- Select
- Select
- Select
- Select
(Setup) → Touch Operation → Touch Panel Settings → Shooting Screen → Touch Func. in Shooting → Touch AE
- Select
Multi-angle LCD screen
Custom function
How to enable the custom function
To assign a function to a button or dial, select
Godta YouTube-informasjonskapsler for å se denne videoen
Gå til innstillingene for informasjonskapsler nedenfor, og slå på YouTube-informasjonskapsler i «Functional»-delen.
Registrer produktet
Få tilgang til all informasjon, hold produktet ditt oppdatert og få gode tilbud
Nettsamfunnet til Sony
Gå til nettsamfunnet vårt, og del opplevelsene og løsningene dine med andre Sony-kunder
Kontakt kundestøtte
Kontakt kundestøtteteamet hos Sony
Reparasjon og garanti
Bestill, spor eller unngå kanskje til og med en reparasjon
