Sony avduker objektivet FE 100-400 mm F4.5 GM OSS
Sony lanserer FE 100-400mm F4.5 GM OSS, et nytt supertelezoom-objektiv i G Master-serien. Med en konstant blenderåpning på F4.5 og autofokus som er opptil tre ganger raskere enn forgjengeren, er dette objektivet ideelt for fotografer innen natur, sport og fotojournalistikk.
Se bilder her.
Les hele pressemeldingen på engelsk nedenfor.
Sony Unveils the FE 100-400mm F4.5 GM OSS G Master™
Super-telephoto zoom with constant F4.5 aperture, autofocus up to 3x faster1,2, and outstanding mobility
May 13, 2026 — Sony introduces the FE 100-400mm F4.5 GM OSS, the newest addition to its flagship G Master™ lens series for full-frame Alpha™ E-mount cameras. Covering a 100-400 mm focal range with a constant F4.5 aperture, the lens delivers the exceptional resolution and bokeh that define the G Master series, high-precision autofocus (AF) up to approximately 3x faster [1,2] than the FE 100-400mm F4.5-5.6 GM OSS. Weighing approximately 65 oz. (1,840 g) with an internal zoom structure, its stable weight balance offers highly mobile shooting capabilities. The FE 100-400mm F4.5 GM OSS gives wildlife, birding, sports, and photojournalism creators the speed, reach, and image quality to capture decisive moments in any environment, expanding their creative possibilities.
"Our creators want super-telephoto reach with G Master optical quality in a body light enough to shoot handheld all day. The FE 100-400mm F4.5 GM OSS delivers constant F4.5 aperture, dramatically faster autofocus, and a build that keeps up with the user’s instincts, whether tracking a bird in flight or working the sideline at a championship match," said Yoshioka Naoto, Head of Marketing, Imaging, Products and Solutions, Sony Europe.
Key features of FE 100-400mm F4.5 GM OSS G Master™:
Uncompromising G Master Optics
  • Resolves fine detail across the full 100-400 mm zoom range, even wide open at F4.5
  • Optical design featuring newly developed ED XA (Extra-low Dispersion extreme aspherical), XA (extreme aspherical), two Super ED (extra-low Dispersion), and three ED glass elements, effectively controlling multiple aberrations including chromatic and spherical aberration to achieve exceptional resolution from center to edge across the entire zoom range
  • Nano AR Coating II reduces ghosting and flare for high-contrast results in backlit conditions
  • 11-blade circular aperture with precision spherical aberration control produces the signature G Master bokeh
  • Constant F4.5 maximum aperture eliminates exposure shifts while zooming
  • Compatible with optional teleconverters [3] for focal lengths up to 800 mm or 1,200 mm in APS-C [4]
Autofocus That Keeps Pace with the Action
  • Four custom-optimized XD (extreme dynamic) Linear Motors, a floating focus mechanism, and the latest AF algorithms deliver AF speeds up to 3x faster [1,2] with approximately 50 % improved subject tracking [2]
  • Fully compatible with Alpha 9 III continuous shooting at up to 120 fps5 with AF/AE tracking
Lightweight Build, Exceptional Mobility
  • Combining the latest optical design, mechanical engineering with lightweight yet robust magnesium alloy barrel components, and high-efficiency, high-thrust XD Linear Motors, the lens achieves a lightweight and robust body at approximately 65 oz. (1,840 g)
  • Inner-zoom design maintains constant length and stable center of gravity throughout the zoom range for precise framing adjustments without shifting balance
Professional-Grade Control and Reliability
  • Built-in stabilization supports Active Mode and coordinates internal stabilization control on compatible bodies
  • Supports the camera body's breathing compensation [6], correcting angle-of-view shifts during focus adjustments in video recording
  • Four focus hold buttons [7] and a dedicated function ring for intuitive, personalized operation in the field
  • Dust and moisture resistant design [8] with fluorine front-element coating maintains reliable performance in challenging conditions
Pricing and Availability
The FE 100-400mm F4.5 GM OSS will be available in June for approximately €5,000 / 59 000 KR. The FE 100-400mm F4.5 GM OSS product video can be viewed here: [link]
For more information, visit: https://www.sony.no/electronics/kameralinser/sel100400mc
Exclusive stories and exciting new content shot with the new FE 100-400mm F4.5 GM OSS and Sony's other imaging products can be found at Alpha Universe a site created to inform, educate, and inspire content creators.
Nucleus PR Agency
Publicis Nucleus
About Sony Corporation
Sony Corporation is a wholly owned subsidiary of Sony Group Corporation and is responsible for the Entertainment, Technology & Services (ET&S) business in the Sony Group. With the vision to "continue to deliver Kando and Anshin* to people and society across the world through the pursuit of technology and new challenges," Sony Corporation supports the Sony Group with technology to create the entertainment of the future together with creators. For more information, visit: www.sony.net
* Both Japanese words, Kando means emotion and Anshin has various meanings such as peace of mind, reassurance, reliability and trust.
Notes:
1 Compared to the FE 100-400mm F4.5-5.6 GM OSS.
2 When mounted on the Alpha 9 III. Compared to the FE 100-400mm F4.5-5.6 GM OSS. Based on Sony test conditions.
3 Compatible with 1.4x Teleconverter (SEL14TC) and 2x Teleconverter (SEL20TC).
4 With 2x Teleconverter (SEL20TC) attached.
5 Based on Sony test conditions. Continuous shooting speed may decrease depending on shooting conditions. When focus mode is set to AF-C, continuous shooting speed varies
depending on the lens attached. Please check the lens compatibility information support page for details.
6 Please refer to support information for compatible cameras. When this function is set to [On], angle of view and image quality may change slightly. Depending on the lens, compensation may not be fully effective even when this function is set to [On].
7 Assignable functions vary depending on the camera used. Please refer to support information for compatible cameras for details.
8 The lens is designed with dust and moisture resistance in mind but is not completely sealed against dust or water droplets.
