Sony lanserer Alpha 1 II
En kombinasjon av høy oppløsning, hastighet og AI-gjenkjenning designet for en rekke profesjonelle bruksområder.
Sony lanserer et nytt flaggskip – andre generasjon Alpha™ 1 II. Fullformatskameraet er speilløst med utskiftbart objektiv, og er drevet av Sonys nyeste AI-prosessorenhet. Kameraet har en oppløsningssensor på omtrent 50.1 effektive megapiksler, opptil 30 fps blackout-fri kontinuerlig fotografering med AF/AE-sporing, anti-forvrengningslukker og forbedret bildeklarhet på middels til høy følsomhet.
Sony announces second-generation flagship Alpha 1 II full-frame camera
A combination of high-resolution, speed, and AI recognition designed for a variety of professional applications
Sony introduces the second-generation Alpha™ 1 II, a new flagship full-frame mirrorless interchangeable lens camera powered by Sony's latest AI processing unit. The camera features an approximate effective 50.1 MP (megapixel) resolution sensor, up to 30 fps (frames-per-second) blackout-free continuous shooting with AF/AE tracking[i], an anti-distortion shutter, and improved image clarity at mid-to-high sensitivities. The AI processing unit brings advanced AI-based subject recognition performance and features including a new “Auto” mode which can detect a wide variety of subjects. In addition, the Alpha 1 II also inherits innovations from the Alpha 9 III, including Pre-Capture of up to one second[ii], and an improved ergonomic design. The camera maintains a lightweight form factor of approximately 743 grams (1 lb, 7.3 oz)[iii] for usability in a variety of professional scenarios.
“The original Alpha 1 was a groundbreaking market introduction when it was released back in 2021, however Sony has developed a range of new technologies since then—this was our opportunity to ensure our flagship camera includes all of our latest innovations.” Said Yann Salmon Legagneur, Head of IP&S Marketing, Sony Europe. “The Alpha 1 II is designed for ultimate versatility combining resolution, speed, AI-based subject recognition, and efficient workflow. This is a distinct tool for professionals ranging from photojournalism, commercial work, portraiture, wedding photography, wildlife, and sports.”
In a world of expanding technology and increasing AI, the ability to authenticate a photograph is now more critical than ever before. Images captured with the Alpha 1 II will be compatible[iv] with Sony’s Camera Authenticity Solution that adds authenticity information[v]in real time in effort to aid in the fight against manipulated imagery and AI-generated fakes.
High-resolution, speed, and AI combination
The Alpha 1 II produces high-resolution images with a wide dynamic range through the combination of the full-frame Exmor RS® stacked CMOS sensor with approx. 50.1 effective MP resolution and the latest BIONZ XR® image processing engine. The camera delivers high-resolution images even in APS-C crop mode, capturing approximately 21 effective MP.
The camera offers blackout-free high-speed continuous shooting with AF/AE tracking at up to 30 frames per second[vi], which can track complex movements with AF/AE calculations at up to 120 times per second[vii]. The camera also includes the highly requested Pre-Capture function, which allows images to be captured up-to one second before the shutter button is pressed[viii], and the Continuous Shooting Speed Boost that can temporarily change the burst shooting speed.
In addition, Real-time Recognition AF has been added to the latest Alpha 1 II with the addition of the AI processing unit. This technology maintains focus on subjects, including a human pose estimation that instantly recognises a person's head and torso, as well as accurately tracks animals, birds, insects, and vehicles. The Alpha 1 II introduces the latest evolution to Real-time Recognition AF with a newly added “Auto” feature that allows the camera to automatically recognise the subject target without specifying a subject mode[ix].
Stable shooting with reduced distortion and noise
To support the need for high-performing speed required by many professionals, the Alpha 1 II features an anti-distortion shutter that enables shooting with reduced distortion. The low noise performance at mid- to high-sensitivity, which is highly requested by professional photographers, has also been improved through tuning, allowing you to capture images with less noise and clear backgrounds even in indoor sports where a high shutter speed is required.
Additionally, the Alpha 1 II has impressive improved optical image stabilisation of up to 8.5 stops (center) and 7.0 stops (periphery)[x] when shooting still images, as well as a newly supported Dynamic active Mode for video shooting[xi].
Comfortable operability and highly responsive workflow
The camera features a 3.2-type LCD monitor with a highly requested 4-axis multi-angle that can be freely adjusted to any angle. This second-generation camera body has improved ergonomics compared to the original Alpha 1, including thoughtful design updates to the grip, position of the shutter button, and evolved custom buttons.
The Alpha 1 II includes a new deep-type padded eyepiece cup (model FDA-EP21) accessory for additional viewing support. A standard eyepiece comes attached to the camera by default but can be swapped with the deep pad option based on the user’s preference.
For additional battery support, the Alpha 1 II comes with the BC-ZD1 Dual-Battery Charger that rapidly and stably charges two Z batteries (model NP-FZ100) simultaneously in 155 minutes to full charge[xii]. In addition, the VG-C5[xiii] compatible vertical grip offers additional ergonomic support with additional battery performance for extending shooting needs.
For professionals seeking a quick, real-time image transfer solution, the Alpha 1 II supports 2.5GBASE-T via wired LAN. Furthermore, when combined with the 5G portable data transmitter PDT-FP1 (sold separately), captured data can be transmitted via stable, high-speed 5G communication. This high level of connectivity dramatically improves workflows from data transfer to content creation and distribution, increasing the work efficiency of professionals.
Additionally, captured data can be automatically transferred to Adobe Lightroom™ or Google Drive™ via Sony's cloud storage service, Creators' Cloud[xiv]. This makes editing work after shooting even more convenient.
Environmentally conscious packaging
To prioritise sustainability, this model’s packaging is entirely free of plastic, marking the first Alpha series camera (excluding ZV-series) to use Sony’s Original Blended Material—a unique mix of bamboo, sugarcane, and recycled paper[xv].
Pricing and availability
The Alpha 1 II will be available in December 2024 for approximately 89 000 NOK at a variety of Sony’s authorised dealers.
For detailed product information about the Alpha 1 II, please visit here
For detailed product information about the FDA-EP21 eyepiece cup, please visit here
For detailed product information about the BC-ZD1 Dual Battery Charger, please visit here
[i] When using electronic shutter. Sony test conditions. Maximum continuous frame rate may be lower in some shooting conditions. Continuous shooting speed may vary depending on the lens used in AF-C focus modes. Visit Sony’s support web page for lens compatibility information.
[ii] Maximum pre-capture time may be less in some situations. High continuous shooting speeds can cause an increase in camera temperature. Pre-capture may be limited to protect the device in high ambient temperature conditions.
[iii] Including a battery and standard media card.
[iv] The Camera Authenticity Solution is available through a separate upgrade license, and this will be supported in a camera software update after January 2025. As of the announcement day, support for the Camera Authenticity Solution is available to select media.
[v] Metadata including provenance information, authenticity of the image captured with the camera, and 3D depth information are embedded into the captured image as an in-camera digital signature.
[vi] When using electronic shutter. Sony test conditions. Maximum continuous frame rate may be lower in some shooting conditions. Continuous shooting speed may vary depending on the lens used in AF-C focus modes. Visit Sony’s support web page for lens compatibility information.
[vii] At shutter speeds of 1/125 sec. or higher. May be less depending on shooting conditions and the lens used.
[viii] Maximum pre-capture time may be less in some situations. High continuous shooting speeds can cause an increase in camera temperature. Pre-capture may be limited to protect the device in high ambient temperature conditions.
[ix] When Auto is selected the camera will normally recognise the subject type automatically, but the wrong type may be selected in some situations. In such cases manually selecting the intended subject type may solve the problem.
[x] CIPA 2024 standards. Pitch/Yaw/Roll compensation. FE 50mm F1.2 GM lens. Long exposure NR off.
[xi] Dynamic Active Mode is not available when shooting in 8K or at frame rates of 120 fps or higher.
[xii] Simultaneous two-battery charging requires a USB PD (30 W min.) compatible power and cable (3 A min.) The CHARGE lamp will turn off when battery charge level exceeds 90% (operational charge). Continue charging for another 30 minutes to achieve a full charge. Actual performance varies based on settings, environmental conditions, and usage.
[xiii] The VG-C5 vertical grip is sold separately.
[xiv] Priory settings in the Creators' Cloud mobile application "Creators' App" or "Creators' Cloud Web" is necessary.
[xv] Not including materials used in coatings and adhesives.
